NO print for Riso GR 1700?
  • jewen25
    • Mar 2009
    • 197
    i have new for digital duplicators, my friend Riso GR 1700,when we try to print its no Image, what is the the problem of this? pls help to trouble shot this problem tnx....
    ERROR HELP ME AND HELP YOU
  • JustManuals
    • Jan 2006
    • 9838
    Re: NO print for Riso GR 1700?
    http://www.justmanuals.com/riso-netw...l-p-14670.html
    $12.77 and instant download.
    • ravikumarj
      • Apr 2007
      • 49
      Hope the Master is not reversed?! Check proper direction?
      Is that master having image through the thermal head.
      • jermyth
        Riso dude
        • Mar 2011
        • 440
        Is the drum dry? Is the impression roller going up against the drum? Have you tried to print from Test Mode? Need some more info here.
        • martincrow
          If you can elobrate the problem faced during prints then it will be easier for members to help you in this regard, i think we can help after getting detailed information related to your riso gr.
          • montana
            • Aug 2008
            • 393
            hi..in test mode try pumping ink and check the master if it is inked and stuck on the cylinder
