RP3700 give code T03-522
  • wwq428
    • Aug 2025
    [Error Code] RP3700 give code T03-522
    Hello everyone, my RP3700 shows me T03-522, and i have no idea of how to fixt it.
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: RP3700 give code T03-522
    There is no T03-522 for the rp3700. There is a T01-522, which is position B sensor does not go ON/OFF while the main motor is operating.
    If you remove the rear cover, move the pcbs, you will see a sensor on the support plate/frame for the drive, about the middle of the frame. Unscrew the sensor plate and blow out the sensor. Reattach sensor plate and pcbs. Good luck.
    • wwq428
      Thanks so much Jermyth, i will try the way you suggested, thank you.
      • wwq428
        hi, sorry, it's code t03-502
        • mikadonovan
          • May 2008
          • 2931
          It's a clamp sensor error. (on top of the drum, holds the master). Make sure the magnet A on the rear of the drum is not loose. Could be a problem with the clamp motor or solenoid, too.
          NEVER ASSUME ANYTHING
          • jermyth
            Riso dude
            • Mar 2011
            • 441
            Sorry Mikadonoran, but the RP clamp ass`y does not have a magnet on. Thats on the GR. The RP uses a motor with two photo- interrupts and a half moon disk. It is located behind the pcbs at the top of the unit. Either the sensors are dirty or the motor/gears are broken or the clamp itself is damaged.
            • mikadonovan
              • May 2008
              • 2931
              Oooops, your right, different model.
