RN 2150 T98-035 code
  • monham
    • Jun 2012
    • 16
    I have been called to fix a Risograph rn 2150. When it comes on, it shows a T98-035 code. If I try to reset it, it comes back to T98-035. I have looked at the service manual and it does not list the T98-035 code. Could somebody please help.
    Thanking you in advance,
    monham
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: RN 2150 T98-035 code
    How are you trying to reset the code? The code is listed as check-sum error on RN EEPROM.
    • monham
      • Jun 2012
      • 16
      Thanks for your insight; however, how do I correct this check sum error? Thanks again -monham.
      • jermyth
        Riso dude
        • Mar 2011
        • 441
        Turn the machine off, hold the reset all button down while turning the machine back on, holding the reset key for a few seconds.
        If the error returns, then you got a hardware problem. Good luck.
        • monham
          • Jun 2012
          • 16
          Thanks for your help. However, I had already held down the reset button and turn on the machine, but the code still returns. What I need help with is how to know what hardware failure I have. Thanks again.
          • jermyth
            Riso dude
            • Mar 2011
            • 441
            Something is wrong with your main PCB. Either the EEPROM is loose, gone, or bad. Or a conntector or two are loose or come out. Reseat all connectors and the EEPROM.
