Risograph tr1510 (no image on master)
  • legaspiclg
    • Oct 2011
    • 72
    [Misc] Risograph tr1510 (no image on master)
    hI EVERYBODY,
    Good day, I have my problem with my RISOGRAPH TR1510. After i scanned the document, there is no print, when i check the Master, there was no image on it.
    Please help.
    Legaspiclg
  • Iowatech
    Not a service manager
    • 3930
    Re: Risograph tr1510 (no image on master)
    Well, here's a couple of things - try resetting the memory by holding down the reset key while turning the machine on. But only do that once,
    If that doesn't work, make sure all the connectors from the main board to the thermal head are are connected correctly.
    If that doesn't work, it is likely the thermal head on that machine is bad.
    Still, good luck!
    • sweet.persona
      Engineer
      • Nov 2009
      • 415
      thermal head
      A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
      DAMENE ABDEL AZIZ
      DJELFA
      • richwalker
        • Mar 2013
        • 30
        It could also be that the master was loaded incorrectly and so the thermal side (shiny) is not touching the Thermal print head so it cannot burn the info on the master.
        Richwalker
        • feak2012
          hi, sir, u shall check your THR connection, if connected well, u shall change your THR.
          Sean
