Riso GR2710 scraper unit problem!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Jamming] Riso GR2710 scraper unit problem!
    Hi to all
    i have problem in riso GR2710 after i resolved cutter and clamp problem , Now when i scanning document everything is well , but when i start copying Paper blocking on paper feed tray and i notice that ( the pickup roller ) does not rotate and not pull papers and machine desplaying up Jam in the tray.
    i have checked and cleaning pickup roller
    i have cheked roller guide
    i have too checked and cleaning paper feed clutch
    and i replace the One-way spring.
    but without result.
    can anyone explain to me what is the problem!!!
    thank you in advance!
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • 20gaugeO/U
    • 557
    Re: Riso GR2710 scraper unit problem!
    If the clutch fires and the silver Feed Tire shaft spins but the FT does not, you have the FT one way cores on backwards.
