Risograph GR3710
  • tmanamore
    • Sep 2009
    • 74
    Risograph GR3710
    My Riso GR3710 is printing light. Adjusting the density doesn't help. I cleaned the screen and still light. Can anyone stear me in the right direction?
  • Iowatech
    Not a service manager
    • 3930
    Re: Risograph GR3710
    Have you tried to reset the machine?
    • RRodgers
      • Jun 2009
      • 1947
      Cleaned the TP?
      • sweet.persona
        Engineer
        • Nov 2009
        • 414
        you may have bad thermal head ( maybe does't carving well in the master) clean or replace it
        A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
        DAMENE ABDEL AZIZ
        DJELFA
        • Iowatech
          • 3930
          In the drum, the one way bearing in the pulley that drives the squeegee roller might have separated or got filled up with ink, or the rod that produces the ink bead's cylindrical shape between the squeegee and doctor rollers might be broken, but it really sounds like you need to reset the machine, put a confidential master on the drum, and then run at least a half ream of paper through to let the drum re-ink first.
          You can pull the ink bottle out of the drum, then look into the cavity where the bottle goes and see the ink bead (sometimes it is helpful to press the drum home button while looking), that will give you greater insight into what's going on.
          Last edited by Iowatech; 03-17-2013, 02:10 AM. Reason: Improper use of the word "a"
          • tmanamore
            • Sep 2009
            • 74
            What is the process for resetting the machine?
