I've got the listed Riso and have had an issue with the Cylinder. Client doesn't use is all the time but I wouldn't think that it should not fill or fully impregnate the Master if it is idle for a month or two. It is the second Cylinder I have had issues with. Anyone have this as an issue and is there a good fix? Thank you for your input.
Riso 220UI - Cylinder Issue
Re: Riso 220UI - Cylinder Issue
This is a common problem when drums sit idle for any length of time; it is even worse now that RISO uses soy-based ink, which quickly gels and clogs the screen.
see the post below, and search this section of the forum for similar responses-
http://www.copytechnet.com/forums/di...d-up-drum.html2000 mockingbirds = 2 kilomockingbirds
