Need help with Riso 7050 " S03-2013 "
  • soriasat
    • Jun 2013
    • 8
    [Error Code] Need help with Riso 7050 " S03-2013 "
    Hello , everybody
    I would ask you for help me with :
    Riso 7050 comcolor
    error code " S03-2013"
    and
    error code " S35-2083-2"
    Please I need " service manual " for Riso7050 .
  • soriasat
    • Jun 2013
    • 8
    Re: Need help with Riso 7050 " S03-2013 "
    any ansower , please ?
    • 20gaugeO/U
      • 557
      Service Manual Requests
      • kyrenecopy
        • Apr 2012
        • 205
        error code " S03-2013" belt platen raise/lower error, the BP elevation motor was driven but did not stop in time
        and
        error code " S35-2083-2" magenta ink supply error, ink detection sensor not sensing ink
        Testing 1-2-3, testing, testing. Is this thing on?
        • soriasat
          • Jun 2013
          • 8
          Thank you very much .
          I looking for Technical Manual for Riso 7050 , and I would ask you please to help me .
          and how can run the machine at " test mode "
          • soriasat
            • Jun 2013
            • 8
            Hello
            Now ,, I get this error " S03-2012-2 "
            Please help me
            • kyrenecopy
              • Apr 2012
              • 205
              Originally posted by soriasat
              Hello
              Please help me
              See attachment
              • soriasat
                • Jun 2013
                • 8
                Thank you
                I will try again today ,, and tell you what happend .
                I would ask you Please if you can attach another technical documents about Riso 7050
                • soriasat
                  • Jun 2013
                  • 8
                  Hello everybody
                  Hello mr, kyrenecopy
                  Today when I try resolve the lastest errors .
                  after run test mode .
                  there are still this error code .
                  And I don't know what I can do with it .
                  I would ask you Please Help me , What the steps that must taken to resolve this problems ?
                  • aliburotic
                    • Apr 2014
                    • 10
                    Hello everybody
                    [ATTACH=CONFIG]21177[/ATTACH]
                    [ATTACH=CONFIG]21174[/ATTACH]
                    [ATTACH=CONFIG]21175[/ATTACH]
                    [ATTACH=CONFIG]21178[/ATTACH]
                    hello soriasat
                    I have the same problems with a riso comcolor 9150.
                    the part on the pictures was blocked and after generated error s03...
                    how did you resolve your problems pls ?
                    • soriasat
                      • Jun 2013
                      • 8
                      Hello
                      to resolve "S03-2013" series
                      You must use the tool to adjust the balance of the BP elevation
                      That was Installed by 4 Cable
                      The 4 cable should make the perfectly balanced BP elevation
                      Best greats
                      • aliburotic
                        • Apr 2014
                        • 10
                        Hello
                        error s03 was cleared now.
                        i get a new error s98-1812-03 or s98-1811-03
                        did you have a solution pls
                        thanks for your big helpful
                        • hasan5900
                          • Dec 2015
                          • 13
