master area 4 light on
  • pc123321
    • Dec 2012
    • 103
    TURN ON RISO 390 master area --location 4 light on
    turn on powerand press print left and right arrow test mode not working
    friday making a master , not took out old master then making the master
    the light on master area 4
    any advice are welcome
  • Iowatech
    Not a service manager
    • 3930
    Re: master area 4 light on
    More information, please?
    Check the white plastic rollers on the drum for damage first, I guess. There are three of them.
    • pc123321
      • Dec 2012
      • 103
      my riso 390 have some problem for master remove
      then we manual took out the master each time before master making
      sometime master making correct but it still in the chamber an error happen
      so we took out the used master ,and turn off the machine
      press print position and turn on machine do the test mode to see the drum clamp plate open and close
      881 enter --stop
      884 start
      884
      884
      this check the clamp plate open and close
      then 887 because one master already making --
      take drum out and clean ,put it back turn off the machine
      turn on machine again do the normal printing ---
      this time old master did not took out do the same thing as before but master making area light on area 4
      drum and master green button , light off
      • Iowatech
        • 3930
        881 enter --stop
        884 start
        884
        884
        Thanks!
        Still, you need to check the white plastic rollers, most likely in this case the one on the bar just clockwise from the master clamp. That bar pushes the master out from under the master clamp so that the master will ride up the master removal hooks and into the disposal rollers.
        Just for future reference, cleaning the drum will not make any difference for a master removal problem unless you can visually see an obvious problem with drum inking. No need to get your hands inked up for nothing.
        One other thing - you can use normal English here, it's kind of tough to efficiently find the answer you need if you don't do that.
        • pc123321
          • Dec 2012
          • 103
          Thanks!
          master removal procedure had a long time abnormal , machine only do the master making and printing
          master sensor bad (master removal unit) ?
          • jermyth
            Riso dude
            • Mar 2011
            • 440
            What's the error code on the display? That will help point to master loading or disposal for the begining of the problem.
            • pc123321
              • Dec 2012
              • 103
              like you said , i also wish the machine will show me the error code ,
              no , no error code only on the face screen location 4 light on
              print drum and master release button light off when you push the botton
              only way is there is a small hole for the screw driver insert in and release the print drum and master making unit
              • pc123321
                • Dec 2012
                • 103
                thanks for tech people---
                problem solved
                serviceman safety switch --back cover
                master disposal box safety switch
                print drum safety switch
                master making unit safety switch ----
                pull out master making unit green handle --connect to the master making u lock solenoid ,some worn out on plastic cause the problem
