Riso EZ370 light copy quality!!
  • sweet.persona
    Engineer
    • Nov 2009
    • 415
    hi to all
    i have problem with riso ez370 , when i start copying quality is light , i try to print with max density but No result !!!
    can anyone expain ::!
    thank u inadvance.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • jermyth
    Riso dude
    • Mar 2011
    • 440
    Re: Riso EZ370 light copy quality!!
    Does it stay light after 10 - 20 copies? Could be impression roller or inking issues inside drum.
    Good luck.
    • sweet.persona
      Engineer
      • Nov 2009
      • 415
      yes friend i tried to copy 140 papers , but all was light! i have replaced the Drum in Another machine they print well and dark , how i can change the Density value from The Sm!
      thank u in advance
      DAMENE ABDEL AZIZ
      DJELFA
      • Exok
        • Jun 2011
        • 750
        When you say you replaced the drum in another machine, can you be more specific?
        Did you:
        1. Take a drum from a different machine, install it in this machine with the light CQ problem and it worked fine?
        If yes, and you make a new master, is the CQ still good?
        2. You took the drum from the light CQ machine and installed it in a different machine and the CQ looked good?
        If yes, was the master that was made on the original machine still on the drum and looked good on the new machine?
        or did you just take the drum from the light CQ machine, install it in a different machine and make a new master and CQ looked good?
