I had posted earlier about not being able to unlock the drum etc. I found a blown fuse (F5) which is a 3.15 Amp . I replaced it with a 3.0 Amp as it was all I could get. Turned the machine on and it started fine - no error codes! Then it got to the master disposal stage and once more the dreaded "T17-020" code came up. Checked the new fuse and sure enough it had blown. Would the .15A under rated capacity have caused it? I note that same fuse controls the clamp, motor, master disp motor, cutter motor and paperfeed clutch.
I think the problem is caused by the master compress motor either seizing up under load or defective. Problem is that not only is it a lot of work to remove and test, but Riso no longer makes any parts for these machines, which is a real bummer as mine has less than 1 mil and had been running great until now. I would like to know if there is a good chance that I am right about the master compress causing the problem and if so, are these units repairable? Also if anyone knows of another non functioning RP3700 which I could buy for parts. Any advice on other possible causes and solutions would be greatly appreciated. I am very disappointed in Riso's policy not to produce parts for their products after such a relatively short period compared with other mfgs.
