Riso RP3700 DEAD
  • Philh
    • Dec 2011
    • 27
    Riso RP3700 DEAD
    I had posted earlier about not being able to unlock the drum etc. I found a blown fuse (F5) which is a 3.15 Amp . I replaced it with a 3.0 Amp as it was all I could get. Turned the machine on and it started fine - no error codes! Then it got to the master disposal stage and once more the dreaded "T17-020" code came up. Checked the new fuse and sure enough it had blown. Would the .15A under rated capacity have caused it? I note that same fuse controls the clamp, motor, master disp motor, cutter motor and paperfeed clutch.
    I think the problem is caused by the master compress motor either seizing up under load or defective. Problem is that not only is it a lot of work to remove and test, but Riso no longer makes any parts for these machines, which is a real bummer as mine has less than 1 mil and had been running great until now. I would like to know if there is a good chance that I am right about the master compress causing the problem and if so, are these units repairable? Also if anyone knows of another non functioning RP3700 which I could buy for parts. Any advice on other possible causes and solutions would be greatly appreciated. I am very disappointed in Riso's policy not to produce parts for their products after such a relatively short period compared with other mfgs.
  • Iowatech
    Not a service manager
    • 3930
    Re: Riso RP3700 DEAD
    T17 is an error relating to the print and master counters. You might want to check that.
    • mixedfeelings
      • Sep 2010
      • 98
      It was a compression motor causing my fuse blow - are you sure that there isn't a jam in the master disposal system? I resolved all of this by clearing out the discarded master jam (which was WICKED) and replacing the fuse. I got it from a local electronics shop (not radioshack, but i bet they would have the correct fuse too?) - but clearing the jam was critical for preventing the fault.
      Funny that we should be facing the same problem at basically the same time.
      • Philh
        • Dec 2011
        • 27
        I am 80% sure that my problem also lies in the disposal end of things but I had not considered a jam. Sure I had a master hanging off the cylinder but after removing it everything else in there "looked" clear. When I have time I will be removing the master disposal mechanism as I realize not all jammed material is readily visible without getting a few components out of the way first. Before all of this happened I was getting a lot of master feed and disposal problems I always had to start with an empty disposal box as it was not compressing the master. Even then I had to keep rewinding and reinserting the master material several times, so it is highly likely that a piece is stuck somewhere. I hate to have to junk the machine as it has less than 1 mill on it and until recently has worked great. BTW was your jammed master/s readily visible or did you have to remove a few items first before you saw it?
        • mixedfeelings
          • Sep 2010
          • 98
          VERY visible, very gnarly. a piece of master was wrapped around the furthest back (drive side) set of rubberbands very tangled and knotted. I basically had to cut it out.
          • jermyth
            Riso dude
            • Mar 2011
            • 441
            Philp, you might want to make sure all your orings are on. If they get nocked off or missing you'll get all kinds of jams.
            Good luck.
