Riso errors
  • landspeeder
    • Feb 2010
    • 355
    Riso errors
    I have a chance to buy a couple of units one is a:
    RZ220...has a "region 3" error and a
    RZ390 which has a P17..20 error ....
    can somebody tell me what they mean
    Thanks and have agreat one
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • Iowatech
    Not a service manager
    • 3930
    Re: Riso errors
    Not sure about the "Region 3" error, but P17 is that the solenoid counter isn't connected. I'd be kind of suspicious of that one. The counter could just be unplugged, though.
    • RRodgers
      • Jun 2009
      • 1947
      Re: Riso errors
      Did it have a Hecon on it at one point?
      • landspeeder
        • Feb 2010
        • 355
        Re: Riso errors
        I think it had a counter but they are about 2hrs from here and we were looking at buying them..... so what has to be done to make these machines normal again?
        • 20gaugeO/U
          • 553
          Re: Riso errors
          Released in 2004 so kick the tires and see what falls out. What are the copy/master counts and what type of environments did they come out of? Like buying a used car, you never know what you're going to get.
          • landspeeder
            • Feb 2010
            • 355
            Re: Riso errors
            My own feeling exactly...we all here agree...
            • 20gaugeO/U
              • 553
              Re: Riso errors
              There were changes made to the 390/590 drums to stop them from flicking ink out the front top. That's probably the only major problem as long as TPH doesn't have lines and all the other regular maintenance parts. But once again you have to see these things to know if they are shot and listen to it run.
              Good luck
