Hello forum,
we bought a pretty cheap Riso RC 6300 3 months ago - and it worked ok until a few weeks ago. I will try to explain the problem as good as a can - we are Riso newbies!
From the moment we got it the machine sometimes showed T-1 or T-4 error codes - but it always worked after a reset. So we thought we can live with it.
One time one fuse (125V 8A, I think J27) was blown and the motor stopped working, but there were no further problems after replacing the fuse. We printed at least 60 masters with 50-70 copies each with no problems.
The I noticed there was an old master stuck around the wheels at the masters disposal box. I believe due to that there was also ink inside the machine. I managed to remove the old master somehow.
Nevertheless now the big problem began: Now, when the machine is turned on, it seems everything is ok - no error messages. But if we either try to make a new master - or if we push the green button on the right side of the drum unit - the whole machine turns off for a short moment - the display gets dark - and after 1 second it turns back on again. There is no fuse blown doing this.
On the rear side of the machine there are several red LEDs burning. I will post 2 pictures in the next post.
I think it either has to do with the power supply or the motor is dead. Or do you have any other idea?
If you have any useful hints what could be the problem and if there is a way to fix it, we would be glad to hear!
(we tried to get a technician to look at the machine - but the only company in our area we know of refused to come because the machine is too old :-( )
Thanks a lot for your support!
Fabian
Fabian
