Risograph RC 6300 - 'Empty Disposal Box' message
+ More Options
Posts
  • patrick80
    I'm receiving this message despite the box being empty.
    Any suggestions on possible causes?
  • 20gaugeO/U
    • 554
    Re: Risograph RC 6300 - 'Empty Disposal Box' message
    Disposal wrap in the rollers that drive it into the box
    • patrick80
      Thank you much. It does appear to be the problem.
      Is there a simple way to service this, or do I have to start taking this machine apart?
      • 20gaugeO/U
        • 554
        Remove disposal box. Slide scanner all the way over (I think that's how it moves- long time since seen one). One metal clip/locking tab lever on each end of the top disposal roller bar. Unlock it and it should lift straight up. Might want to wear rubber gloves. Check with a flashlight the lower roller assy also and make sure you get all the old master.
