RP3700 Masters not attaching to drums. *A16-525*
  • benjaminography
    • Oct 2014
    • 22
    [Error Code] RP3700 Masters not attaching to drums. *A16-525*
    Hello!
    I am having some serious issues with my RP3700. Here is what has happened -
    • I went to create a new master, and the machine reported a master mis-feed (A02-555, A01-222). Happens alot, so no concern.
    • I re-feed the master a few times, and eventually a new error comes up asking me to manually remove the existing master from the drum (A16-525). There is no master on the drum, or any trace of a master. Also the black strip on the drum is clean and clear.
    • I am unsure at this point if the machine or the drum is at fault, so I reset the machine, and change to another drum.
    • I go to create a new master, and exactly the same issue happens. A few mis-feeds, then the drum is masterless and gives the A16 error.
    • I have tried this a third time since and now have three naked drums, and a machine that doesn't want to give me any masters!
    Could anyone advise my next course of action?
    Thanks in advance!
  • Iowatech
    Not a service manager
    • 3930
    Re: RP3700 Masters not attaching to drums. *A16-525*
    Originally posted by benjaminography
    Hello!
    Thanks in advance!
    Make sure the sensor that detects the master on the drum is clean. I don't have my manuals handy, but if I remember correctly if you take the drum out of the machine you will find that sensor dead center of the upper part of the drum cavity.
    Just curious, you said you reset the machine, what did you do there?
    • benjaminography
      • Oct 2014
      • 22
      Thanks for the reply!
      To reset I switched the machine on and off holding the yellow reset button.
      Just turning it on and off took me to a 'press start to resume' (or something like that) screen. Holding reset allowed me to continue printing with some drums.
      I think I found the little black sensor (it looks about the size of a lego brick). I've given it a blast with some compressed air, but it still isn't working. Would you recommend wiping it with something?
      • Iowatech
        • 3930
        You can try wiping it gently with a soft cloth with a little alcohol on it if the blast of air doesn't help.
        • jermyth
          Riso dude
          • Mar 2011
          • 440
          Also check the clamps on your drums to see if the collars are not broken. If the clamp can't open, or ejection plate can't flip up, you get the same code.
          Good luck.
          • benjaminography
            • Oct 2014
            • 22
            Thanks for the replies everyone!
            I've been away from the machine until this evening, so tried a few things -
            Cleaned the sensor with a cloth (even removed it from the metal panel at the top of the machine so I could get a proper look). The same Master Misfeed error followed by the A16-525 error still happens.
            I tried blindfolding the sensor with a strip of black paper to see if it was still functioning at all - and it fed a Master onto the drum, but didn't cut off, leading to another Master Misfeed error (I am assuming the sensor informs the machine to stop feeding the master roll and cut it off?)
            I am assuming it may be the clamp issue on the drums? I am unfamiliar with these parts, however I am able to get various flaps up each of the drums. It seems unlikely that 3 of my 10 drums would be damaged?
            Any further help would be greatly appreciated! I am starting to get quite worried now!
            • Iowatech
              • 3930
              If you pull the drum out of the machine, there is a black strip just to the left of the master clamp. Make sure it is free of master debris. It should not be shiny.
              Also, check the rollers in the master disposal area to see if there isn't a scrap of master material in there, and make sure all of the o-rings are on their pulleys.
              • benjaminography
                • Oct 2014
                • 22
                Double and triple checked the drums. Found the odd tiny scrap of master under the various flaps, but they are totally master free now, and the black strips are clear.
                Are there any particular rollers I should be looking at? I opened the top of the machine, and opened the lid of the section leading to the master disposal feed (it had little green levers). I've had a check around for anything papery and I can't see much. The rubber bands all seem to be in place.
                • Iowatech
                  • 3930
                  Well, I'm not sure right now. Anything causing problems like this in the master disposal area should be kind of easy to see, so I guess you can stop looking there.
                  I don't know how much this will help, but the A16-525 error code means that when the machine is making a new master, the old master on the drum wasn't removed in time. That leads back to the sensor you found and cleaned earlier. I've seen that sensor get ink on it when there was a master disposal failure, I suppose if you haven't already you might try cleaning the sensor with a soft cloth with a little alcohol on it once and see if that makes a difference.
                  I don't suppose you could upload pictures of the machine when it gives you that error, like inside of the drum cavity or maybe the master clamp area of the drum when that error code occurs? I have a feeling I'm missing something basic, and the pictures might help.
                  • jermyth
                    Riso dude
                    • Mar 2011
                    • 440
                    Check the clamp collars, three on each clamp. One rear side, two front, white plastic washer like. Rear & 1 front are attached to the clamp plate, 2nd front attached to projection plate (ejects master out from under plate). If any of they are missing or broken you can get the same jam code sometimes.
                    Good luck.
                    • benjaminography
                      • Oct 2014
                      • 22
                      Hey Everyone - busy few days, I've only just managed to get some time with the machine.
                      OK. A new weird development.
                      I reset the machine (switched it off/on whilst holding the yellow rest button), and put in my GREEN drum (which already had a master on it). I set it to create a new master - and it was totally fine! Just to check I made a bunch more masters - and it was fine! Put another few drums in which already had masters - and totally fine again.
                      I followed this by putting on the BLUE drum (which is currently naked), set it to create a master, and it comes back with the error again. So no tricking it. The same happened again with my RED drum (which is also naked).
                      Is there a way to manually place a master on a drum?
                      I took some photos inside if anyone wants to see -
                      IMG_1626.jpgIMG_1624.jpgIMG_1623.jpgIMG_1621.jpgIMG_1620.jpgIMG_1614.jpgIMG_1613.jpgIMG_1608.jpgIMG_1606.jpgIMG_1604.jpg
                      • Iowatech
                        • 3930
                        On the left hand side of the control panel there is a button labeled "Confidential". Put the blue or red drum in the machine, then press that button, then press the "Start" button and see what happens.
                        • benjaminography
                          • Oct 2014
                          • 22
                          Hello! Tried CONFIDENTIAL MODE - but the same problems are still happening.
                          • Iowatech
                            • 3930
                            I guess in that case it probably would be easiest to manually put a master on the drum.
                            Get a master out of the master disposal tray . Straighten it out the best you can without laying it on anything, and you will notice one end has a larger ink free area than the other. That's the end that needs to go into the clamp. Make sure that the master is on the inside of the metal support for the drum, at least on the right hand side when looking at the front of the drum. Then try to make a new master.
                            While this should get you started, you might need to make some test prints after that to get rid of the used master's color. Also, this can be pretty messy, so be careful.
                            • benjaminography
                              • Oct 2014
                              • 22
                              Hey Everyone - sorry for the lack of updates - I only just last night attempted the drum fix (its surprisingly hard to get an extra pair of hands sometimes!).
                              Anyway - it totally worked! I applied an old master to the drum as recommended and its all working great now! So a HUGE thankyou for all the advice and help! Hopefully this thread has been helpful for all of you as well!
