RZ-220 Shrink copies
  • ldfrepairs
    • Oct 2012
    • 148
    I tried using the test mode 547 but it does not help. Documents still is smaller. any help?
    drugstore-onlinecatalog.com
  • Iowatech
    Not a service manager
    • 3930
    Re: RZ-220 Shrink copies
    Any chance you could post a picture of what you are experiencing? And maybe the master count?
    I have some ideas about this, but I'd prefer not to take a wild swing at this, tell you wrong things and waste your time.
    • ldfrepairs
      • Oct 2012
      • 148
      Attach are original and copy samples. noticeable is the amount of shrinkage. Master count is 28,417
      • Iowatech
        • 3930
        Sorry, I didn't find any images. You might need to try again.
        • ldfrepairs
          • Oct 2012
          • 148
          my apologies. images are attached
          • 20gaugeO/U
            • 554
            Clean the write roller (I use belt cleaner- trying to rejuvenate the rubber) or just replace the write roller. TM 547 is typically -6, you can go increments of 10 and see how it goes. Turn it to +20 and see if you are on the right track.
            • Iowatech
              • 3930
              +1!
              • ldfrepairs
                • Oct 2012
                • 148
                Update
                Clean the write roller and the quality improved. Will order roller and replacing it should correct issue I guess.
