Be cautious of Copier Careers
  • eddy out
    • Oct 2016
    • 359
    There is a copier tech head hunter called Copier Careers. They can and will find you a job anywhere in the country, but their practices are unscrupulous. Be very careful and fo your own research before you actually move your life for a employment through them.
    • 23008
    Re: Be cautious of Copier Careers
    It sounds as though you had a bad experience.
    Thanks for sharing your experience. =^..^=
    • eddy out
      • Oct 2016
      • 359
      I did... However, I think accepting a job through them could be a good thing if it is an informed decision. I'm happy where I am now, but the job I accepted through them was not what they stated. I moved on years ago. Recently they contacted me again and this post is because they just want the commission. That's why I say to use caution because they don't really care. Perhaps things will be perfect, just do your own research. I guess any head hunter just wants the commission.
      • techsxge
        • Jan 2022
        • 660
        I mean, that seems to be their profession after all.
        That guy is a user on here? I've just seen i've got a reply from someone for my LFE but it does not seem to be the same person
