HL-8360 "Print Unable Z3"
  • theengel
    • Nov 2011
    • 1784
    This is a new one on me. I can't find it anywhere on Google, and I'm unable to find a service manual. I noticed that PR have no parts for the machine, other than toners and drums.
    Any ideas?
  • theengel
    • Nov 2011
    • 1784
    Re: HL-8360 "Print Unable Z3"
    No one?
    Anyone have any idea where I can get a manual?
    • monarke4
      • Oct 2018
      • 185
      Are you sure the model number is not an HL-L8360 DW, CDW, CDWT? Brother's Website does not list a HL-8360.
      In a search I did, I was also unable to find a service manual.
      Some manufacturers are very "tight lipped" about these things.
      If all else fails, contact Brother Support.
      Customer Support - Product Registration - Brother
      • tsbservice
        Field tech
        • 8018
        In Europe we have HL-L8360CDW/T. There is no Print Unable Z3 error, closest I was able to find are:
        Print Unable 03
        Connection failure of the polygon motor harness - Reconnect the polygon motor harness.
        Laser unit failure - Replace the laser unit.
        Main PCB failure - Replace the main PCB ASSY.
        Print Unable ZC
        The power supply waveform is incorrect - Install a voltage stabilizer in the power supply part.
          Originally posted by theengel
          No one?
          Hey Brother.. email me Binky27501@gmail.com
            • 23008
            maybe:
            "Print Unable 23" ?
            • theengel
              • Nov 2011
              • 1784
              The letters after the model number just indicate the printer's options. When I talk about a model, I generally don't include those letters, because it's the same model, no matter what the letters at the end are. At least, the errors are generally the same.
              What do all the letters signify in the printer model numbers?
              • tsbservice
                Field tech
                • 8018
                I can't for the life of me find "Print Unable Z3" neither in Service Manual nor with Google Search, but that's just me.
                Send you PM, just in case things went wrong with getting SM.
                • theengel
                  • Nov 2011
                  • 1784
                  Thanks all.
                  That's insane--to create a service error and not tell us what it is.
                  I think I'm going to label this call "unfixable"
                  • tsbservice
                    Field tech
                    • 8018
                    Thanks all.
                    Can you upload picture of an error display? I'm interested in solving this mystery code.
