Brother MFC 2700/ FAX ISSUE
  • cucuklotz
    • Mar 2007
    • 611
    Hi
    I seem to be getting one headache after another on $200 printers these days.The machine sends faxes ok,but dosnt
    receive them.The display just says private call,but does not pick up as a fax.It is set to fax only and all settings appear ok on user setting printout.
    It is a dedicated line and this just started to happen out of the blue.Not sure what setting changes,I tried a machine reset,but not factory reset.
    Thanks for any help.
    ANDY
    • 23007
    Re: Brother MFC 2700/ FAX ISSUE
    Is the Rx mode set to distinctive ring? A distinctive ring is a non-standard ring combination commonly used when you're using a single phone line for multiple functions. The fax may be set to respond to a distinctive ring like: ring ring pause ring ring, and the phone line is producing: long ring pause long ring. Or vice versa.
    Does the line ring ever? Connect your handset to the line and listen for a ring when you dial from your cell. You phone line should test as follows:
    On hook: 12vdc, 90vac
    Off hook: 52vdc, 12vac
    Ringing: 90vac low, 110 - 125vac high
    It's very common for PBX systems to output a ring signal that the fax does not recognize as a ring.
    Is the phone line connected to the LINE input, not the handset input?
    Is it set to manual reception instead of automatic reception?
    Is there a Reception Restriction function enabled? When enabled Reception Restriction answers only phone numbers that appear in the addressbook.
    • cucuklotz
      • Mar 2007
      • 611
      Hi
      Thank you for replying.Yes it is ringing and distinctive ring is off,It shows in display for every fax coming in "Private Caller"
      Andy
      • tsbservice
        Field tech
        • 8010
        Can you attach printout with fax settings? I would consider Factory reset if it happened out of nowhere.
        Also check this out:
        Online User's Guide
        • cucuklotz
          • Mar 2007
          • 611
          Hi
          I am out today,but I will attach tonite,I have it printed up in my service bag..
          THANK YOU for helping
          Andy
