Error Unable to Print 2A
  • MissRoughRiver
    • Oct 2019
    • 4
    I am having terrible difficulty with Brother printer all in one. I can clear message by turning off for a while and can then print a sheet or two. The machine has been cleaned with compressed air. Belt unit has been wiped. Toner waste unit has been replaced. I hear a clicking as if it is trying to load a page but then stops and 2A error pops back up. Please help.
  • Lance15
    • Jun 2015
    • 1088
    Re: Error Unable to Print 2A
    You posted in the Brother forum, but, you fail to mention the model. Sounds like a color model.
    Are you able to observe the picking action by shining a light in the (maybe) slit from the rear of the printer where the paper tray slides in?
    I'm not a Brother tech. Just trying to get some additional info.
    • MissRoughRiver
      • Oct 2019
      • 4
      Guess you can tell I am NEW to this. Just trying to fix the MFC-9840cdw Brother all in one that I have. What I think I am hearing is the clicking of the mechanism to pick up the paper but its unable to do so. I will go to the internet and see if I can find some you tube videos to help me figure out what you all are telling me. It's been such a good machine...
      • Lance15
        • Jun 2015
        • 1088
        Sorry for the delayed response.
        Is the pickup roller rotating? Maybe the roller is worn or could use some rubber roller rejuvinator in a pinch?
        • tsbservice
          Field tech
          • 8008
          She posited this before in https://www.copytechnet.com/forums/f...al-discussion/
          I think really tech is needed to sort this, sorry Miss.
            • 8193
            The Brother MFC-9840cdw was introduced in 2007 and discontinued in 2011 and sold for less than $500.00 .
            You probably cannot get parts or repair if you tried. Brother MFPs of that era were not designed to be repaired and is considered disposable.
            You can spend $100+ for one hour of technical time that may or may not fix the problem.
            Time to begin shopping for a new MFP and recycle this one. It has no value.
