DCP-8050DN toner won't reset
  • Lance15
    • Jun 2015
    • 1086
    I replaced the toner (TN-620) in this Brother printer, but, it's still saying Toner Low Prepare New Toner Cartridge. I followed the instructions and some troubleshooting I found on Brother's website. It still won't recognize the toner was replaced.
    Here's what I did (following the instructions):
    Remove old toner cartridge from drum unit
    Remove new toner cartridge from box
    Shake toner back and forth
    Remove yellow plastic covering the dev roller
    Install new toner into drum unit
    Clean the corona wire
    Reinstall into the printer
    The printer spins up, warms the fuser and then goes back to Toner Low. Am I missing something?
    Brand new genuine Brother TN-620 purchased from Office Depot.
  • tsbservice
    Field tech
    • 7979
    Re: DCP-8050DN toner won't reset
    Every Brother I know has toner reset sequence of buttons etc. I don't know for this toner as it's not available here, but try this:
    TN-620 & TN-650 Toner Reset Instruction | 123ink.ca blog
    Or just watch some You tube videos how to put reset gears in position for the toner cartridge to be recognized as new.
    Good luck
    • Lance15
      • Jun 2015
      • 1086
      Those instructions aren't for the DCP series. When I was looking at the cartridge, I was thinking more along the lines of a reset gear/mechanism. Looks like I was thinking right. Will have to look at it tomorrow. Thank you for your response.
      Brother TN620, TN650 Toner Reset Gear | Cartridge America
      • Lance15
        • Jun 2015
        • 1086
        I dunno. I'm confused. I reset the gear. Still says Toner Low. Found how to access Maintenance Mode and tested the Toner New (TN) sensor and it's working. I tried resetting the original toner cartridge gear and still get Toner Low. Still prints, just keeps saying Toner Low.
          different model.. I think this pretty much crosses lines tho:
          Reset Developer Roller Counter
          This function allows you to manually perform the same operation as when the toner cartridge
          is replaced with a new one. The purpose of this function is to provide an error resetting
          method in the event that the toner end display was not cleared because the new toner
          cartridge was not detected by the machine for any reason.
          <Operation Procedure>
          Non touch panel models
          (1) Open the front cover.
          (2) Press the [Clear] button.
          "Replace Drum? 1.Yes 2.No" is displayed on the LCD.
          (3) Reset the counter as described below depending on the type of toner.
          Starter toner: Press the [*], [1] and [0] buttons in this order.
          Standard toner: Press the [*], [1] and [1] buttons in this order.
          High yield toner: Press the [*], [1] and [2] buttons in this order.
          Super high yield toner: Press the [*], [1] and [3] buttons in this order.
          When the type of toner is not clear: Press the [*], [0] and [0] buttons in this order.
          (Regarded as the same type as the toner previously set.)
          "Accepted" is displayed on the LCD, and the machine returns to the ready state.
          (4) Close the front cover.
          Touch panel models when "no toner" is not
          displayed
          (2) Press the [1] button.
          "Reset Menu" is displayed on the LCD.
          Press the [ ] or [ ] button to select
          the toner cartridge to be reset, and
          press the [OK] button.
          (3) "Reset? Yes No" is displayed on the
          LCD. Press the [Yes] button.
          state.
          displayed
          (1) Press the [Stop/Exit] button to return the
          LCD to the standby display.
          (2) Open the front cover and then close it.
          (3) While "Please Wait" is displayed on the
          LCD, open the front cover again.
          (4) When "Cover is Open" is displayed on
          the LCD, press the [1] button. "Reset" is
          (5) "Reset? Yes No" is displayed on the
          state.
          (6) Close the front cover.
          • tsbservice
            Field tech
            • 7979
            In case anything is working for new toner to be recognized, I will print settings list and do memory clear from Maintenance mode. Never ever had main PCB going wacky to not recognize new toners at all.
              try the dev reset... or check the right manual for it... have had that problem on a lot of the brother units
              • Lance15
                • Jun 2015
                • 1086
                Phil.....
                Using your method and selecting the [*], [0], [0] option worked! Thank You!
                It doesn't look like Brother chips supplies/parts. I noticed to clear pretty much anything requires the use of the Maintenance Mode.
                  Phil.....
                  Yup sure does.
                  PIA if you ask me.
                  Works when using (uggh) compatible
                  • tsbservice
                    Field tech
                    • 7979
                    Phil.....
                    Glad you worked out this one. Kudos Phil pointed right one.
                      I know at one time I HAD the SM/PL for THAT model.. now poof.
                      But did find out the Dev reset on MANY models over rides the " replace toner " even on the early color/mfp units.
                      Glad to see not ALL the grey matter is failing
                      • Lance15
                        • Jun 2015
                        • 1086
                        Yeah. I came across the SM for the 8040, 8060 and maybe another one. Figured I could figure SOMEthing out between them.
                        It's my personal printer that my wife got for free from work, so, I wasn't so concerned.
