Reset fuser counter for Brother HL-L6400DW
  • Sobknefru
    • Feb 2020
    • 4
    We've successfully replaced the fuser on our machine, but now don't know how to reset the counter. Any help would be much appreciated.
    Re: Reset fuser counter for Brother HL-L6400DW
    end user?
    where did you get the new fuser?
    not from A reputable source?
    all Brother (genuine) and preferred sellers will include a step by step installation and reset sheet.
    did you get one/follow the instructions?
    who rebuilt the fuser for you?
    • Dickie
      • Nov 2011
      • 190
      Maintenance mode usually 82, 84 or 88 (Varies on different models in UK) resets life for most things other than drum or toner.
      If it is just a laser printer you can normally only do it via the Brother BR maintenance package tool available only to authorised dealers.
      You do not get any reset information with fusers as suggested above (Not in the UK anyway, you need to be a dealer to get the tool or have a service manual to find how to enter maintenance mode and which programme to run)
      If unable to reset do not worry the printer will still function O.K but with the irritating maintenance showing
      Sorry not au fait with U.S model numbers as they sometimes vary from the U.K ones
      Hope this helps
      • Sobknefru
        • Feb 2020
        • 4
        end user?
        Brother HL-L6400DW Fuser Unit - 110 / 120 Volt - Up to 200K pages, Genuine (K2086)
        Yes, end user. We got it from the above supplier. It says there that it is a genuine part. Maybe they aren't, I honestly don't know. My boss installed it and no one along the way told him he shouldn't. It didn't come with any instructions. I know that it will work without resetting the counter. Just thought someone here might be able to help.
          I've bought from them.. always had a sheet with reset instruction
          try SM 88
          • Sobknefru
            • Feb 2020
            • 4
            try SM 88
            Sorry, guess I should have been more specific. I don't know how to get it into maintenance mode in the first place. All the instructions that I can find do not work with our printer, unless I'm doing something wrong, which honestly is entirely possible. I really appreciate your help.
              so yo really don't have the service manual for your product?
              10 sec google search found this...
              YouTube
              you didn't search very hard
              • Sobknefru
                • Feb 2020
                • 4
                YouTube
                I looked. I found this, and many other directions. Our printer control panel does not look like this. I'm not an idiot. Posting on this board was after extensive searching and not finding the same control panel as we have, hence my problem.
                • boutn
                  • Jun 2016
                  • 540
                  Was looking for this also.
                  This is what the manual says.
                  • tsbservice
                    Field tech
                    • 7975
                    I have found that old FW version may sometimes prevent execution of code 88. It's also supposed fuser change to be tech not enduser operation.
                    • richs
                      • Nov 2008
                      • 256
                      Straight from the manual
                      Touch panel models
                      (1) Press the [8] key twice in the initial
                      state of maintenance mode. "RB" is
                      displayed on the LCD.
                      (2) If you press the [˄] or [˅] key, item
                      changes as below in Table 1.
                      (3) Press the [SET] key while "RB" is
                      "PartsReplacement" is displayed on
                      the LCD.
                      (4) Press the [SET] key while
                      the LCD.
                      (5) Press the [˄] or [˅] key to display the
                      part with the counter to be reset on
                      the LCD, and press the [SET] key.
                      (6) "*******OK?" is displayed on the LCD.
                      Press the [SET] key to reset the
                      counter for the selected part and
                      return the display to step (2). (*******
                      represents the name of the selected
                      part)
                      (7) Press the [X] key, and the machine
                      returns to the initial state of
                      maintenance mode.
                      or
                      state of maintenance mode. "Reset-
                      Laser Unit" is displayed on the LCD.
                      (2) Press the [˄] or [˅] key to display the
                      the LCD, and press the [Mono] key.
                      (3) "*******OK?" is displayed on the LCD.
                      Press the [Mono] key to reset the
                      return the display to the procedure (2).
                      (******* represents the name of the
                      selected part)
                      (4) Press the [X] key, and the machine
                      maintenance mode.
                      Depending on firmware
