brother if-4100 cant send to 800 numbers
  • tuey
    • Apr 2014
    • 120
    was at a customers office today and saw a 4100 fax that i had not seen before. asked about it and customer says we cant fax to 800 numbers with this so we went back to the canon fax. had a few minutes so i tried it, would not connect, plugged the $100 canon in tried same 800 number , went right through. have seen alot of 4100/4750 through the years but have never had an issue like this. does anyone have any ideas as to what might cause this?? thanks--tomtuey
    • 22997
    Re: brother if-4100 cant send to 800 numbers
    The only time I've ever specifically seen 800 numbers fail was when they were blocked by the phone company. I plugged in the handset and dialed an 800 number ... I got a click, then a dial tone. =^..^=
    • tuey
      • Apr 2014
      • 120
      thats what i thought until i plugged the canon fax in and it went right through. i'm gonna check the brother settings options to see if it could be there (really doubt it) , they say that they have a 4100 at another location that wont connect to 800 numbers either. i think i can rule out the phone line . thanks--tuey
        do you have the SM for the 4100e?
        • tuey
          • Apr 2014
          • 120
          i have the 4750 version, only thing i've ever had to do on these is rebuild doc feed and a couple of fusers.
          • tsbservice
            Field tech
            • 7975
            Stupid question but does it fax to any number? If Yes next thing I would try is to initialize fax.
            • tuey
              • Apr 2014
              • 120
              the doctors were in that office today so i didn't want to be there, i'm going tomorrow. i appreciate the help and really the reset sounds logical and will try it first, thank-you. i've been selling and servicing faxes since they came out, and not being able to send to 800 # is a new one on me. thanks again-- tuey
