Brother MFC9320 CDW- toner won't disengage
  • ChrisG
    • Oct 2013
    • 181
    Printer experienced a power failure (was previously working), came back up and said none of toners could be recognized. Customer was going to reseat the toners, but none of them will release. Checked the error code in service mode and has a C6 error code for the developer release motor. When power cycled with the side cover off, there's no motor movement from any of the motors and just comes back to the unrecognized toner message.
    Was this a common failing of this model or is it more likely the main board took a hit with the power failure?
    Thanks for the input
    Chris
    TJL Copy Products
  • dalewb74
    • Feb 2018
    • 1153
    Re: Brother MFC9320 CDW- toner won't disengage
    are they genuine brother toners? does it have the brother logo on each of them?
      can they remove the drum(s) units?
      sounds like something is binding
      • ChrisG
        • Oct 2013
        • 181
        They were genuine brother drums and toners. Something let go in the main drive pack and due to the cost of the replacement, customer chose to scrap the machine. Thanks for the respones
