Brother MFC L5900DW Light Copy
  • Shtroumf
    • Mar 2019
    • 10
    Im totally lost with this printer/client
    New Brother MFC L5900dw machine that print nicely it worked frome june 2020 to november 2020 perfectly, but now since mid november the copies are light almost unreadable when copying blue pencil ink only, the other part of the page is fine. they use the same pencil brand and color as they used before, same paper, they have a old MFC-2700W that do it perfectly same pencil ink, same paper at their other clinic
    If I manually increase the contrast and density, the copies are fine, but this is a huge hassle to do every time and we shouldn't need to do so. Also, there does not seem to be a way to make increased contrast and density the default settings.
    The problem is the same whether copying from the ADF tray or the glass.
    Brother sent us a replacement machine, and we transferred the same drum and genuine Brother toner cartridge from the first machine to the second, and the problem persist. we tried another compatible toner also
    I contacted brother like 3-4 times, did everything they asked with the client, nothing they can do about that
    Sorry for my bad english
  • tsbservice
    Field tech
    • 8020
    Re: Brother MFC L5900DW Light Copy
    You made a mistake transfering old drum and toner to second machine. Your drum unit probably need to be replaced, those have life around 50k. On a side note it's so easy to make shortcut to predefined copy settings. High counter printers may also need laser unit cleaned/replaced.
    • Shtroumf
      • Mar 2019
      • 10
      we tried another drum also but it is not genuine drum, for the shortcut i did it but the client is sill complaining as it take a little longer with the shortcut
      Print is perfect, if i use a black pencil its not perfect but almost but the client need to use blue pencil only, it was working before so im lost printer is like 7 month only, it was still the original drum 50% life remaining when the problem started to happend
      • tsbservice
        Field tech
        • 8020
        Don't use compatible drums they will do exactly what you described. Change the drum unit with OEM -> problem solved!
        • Shtroumf
          • Mar 2019
          • 10
          i understand but the problem started with the original genuine brother drum, currently they are still using this drum and the problem remain, we tried only the compatible one for 5 minutes to test and the problem was also present and only when they write with these blue pencil its so weird
          • dalewb74
            • Feb 2018
            • 1157
            brother does not agree with generic products such as toner or drum. second copiers weren't designed for reading pencil, nor pen. i hear it from time to time the customer says well it used to do it. why doesn't it do it now? because you got lucky it wasn't designed to do what you are trying to do. but i agree with the others if you replace the drum with a genuine brother drum that will probably take care of the issue.
              and clean the scanner glasses...
              true brothers do not play well with compatible ANYTHING
              • Shtroumf
                • Mar 2019
                • 10
                Thanks i will try that on monday when the office open
                if this doesnt works, what brand of printer do you suggest all they do is copy pencil ink (blue) all day
                • Drivee
                  • Nov 2020
                  • 322
                  Any Canon or HP MFP printer..
                  • miller01123@gmail.com
                    • Jun 2019
                    • 55
                    Get a darker blue pencil. Most copiers have a hard time seeing light blue pencil, IME.Especially a cheap one.
                    • Shtroumf
                      • Mar 2019
                      • 10
                      I found a way to put the printer in high contrast or other copy mode without having to make a shortcut
                      If you use the brother remote configuration tool it works
                      The client is happy for now, problem solved
                      Thanks for the help, if the problem happen again i think i will tell them to get darker blue pencil like suggested
