MFC-L3750
  • aAandy
    • Apr 2012
    • 370
    MFC-L3750
    client put in new aftermarket toners & manually reset toner counts - machine is not recognising one (or more) of the toners at all, but it doesn't say which one! just displays "no toner"
    client replaced all the colors with genuine (not K) so i advised them to get a genuine K
    how the heck are you supposed to know which toner is 'missing'?
    • 22999
    Re: MFC-L3750
    Is it networked? Maybe there's more useful information on the web interface. =^..^=
    • aAandy
      • Apr 2012
      • 370
      Re: MFC-L3750
      connected via USB, but i will take my laptop & use a crossover and see if there's more info in the web interface
      • Gift
        • Mar 2011
        • 2458
        Re: MFC-L3750
        Yes you should see a "!" for the affected color via webinterface while the display itself isn't much helpful...
        • masterchill
          • Jul 2005
          • 100
          Re: MFC-L3750
          Using Maintenance Mode function code 82 can help determine which color is giving the issue.
          2500Black toner cartridge could notcommunicate with the cartridgesensor.
          2501Yellow toner cartridge could notcommunicate with the cartridgesensor.
          2502Cyan toner cartridge could notcommunicate with the cartridgesensor.
          2503Magenta toner cartridge could notcommunicate with the cartridgesensor.
