Toner Empty L 6300DW
  • i-have-fax-problems
    • Mar 2020
    • 98
    We replaced a toner (because of toner emtpy message) (new one was a full one original) but perhaps it was used before so the white gear mechanism couldn't reset the toner message. So I resettet the toner via the panel (cover open - arrow down and curved arrow pressed simultaniously). Now Toner empty message again but toner is still quite full.
    Are there any known issues when toner empty is being displayed again and again.
    I resettet the toner this time (Its a original one) with turning the white gear on the side of the toner).
    Thank you.
  • tsbservice
    Field tech
    • 7908
    Try to reset with another toner capacity.
    • tonerjockey
      • Apr 2014
      • 553
      if your model has the toner sensor window also, try a little black tape over it and see what happens after another manual reset.
      how about a firmware update?
