Fax 2840 longer Original Documents
  • i-have-fax-problems
    • Mar 2020
    • 105
    Does this model have a software switch so that you can send longer original documents. The maximal document length is restricted to i don't know which length. I know
    that older models (but not brother) had sometimes a softwitch where you could allow longer documents. Customer wants to send documents with length 60 cm. He has
    an old minolta fax 1600 with which he can send this long documents.
  • tsbservice
    Field tech
    • 8013
    Re: Fax 2840 longer Original Documents
    Try WSW 16 selector 7 set it to 1(Max. document length limitation - 1: 90 cm).
