Brother DCP-9045CDN - Print Unable 32 error
  • barakm
    • Jan 2023
    • 24
    [reposting due to type in the error code]
    Hi everybody !
    I have a Brother DCP-9045CDN machine that displays the "print unable 32" error.
    I followed the manual and searched for jams - all paths seem clear.
    I did some reading here on the forum, searched the web, read the service manual and I have a feeling
    that this is the "solenoid sticking" issue that was discussed here.
    In order to verify that this is indeed the issue, I used the service menu on the printer in order to get
    a readout of the sensors. Now here is my question:
    The service manual states that error 32 is a problem with the density sensor shutter.
    However, the manual does not refer to such a sensor!
    I am a newbie, and maybe this is a stupid question, but can the "density sensor" refer to the registration-mark sensor(s) ?
    It's just that the list of sensors do not contain any reference to a density sensor!
    Any hint or advice will be welcome...
    Thanks in advance,
    - Barak
  • dalewb74
    • Feb 2018
    • 1167
    Re: Brother DCP-9045CDN - Print Unable 32 error
    did you follow the 5 steps for the user check in the service manual?
    • barakm
      • Jan 2023
      • 24
      I did check the harnesses (that looked fine), and then got to the shutter, which indeed was stuck.
      I applied the "tape fix" (put a piece of scotch tape on the sticking foam) and the shutter stopped sticking.
      I reconnected everything and the machine passed the power-up sequence without a fault.
      When I tried to print, I got 2 "paper jam" errors (though a page was not pulled at all), and then the "Print Unable 32"
      returned. I checked the shutter again, but it seems to be ok (it's not sticking anymore).
      I can't try replacing the PCBs, since I'm not a technician, just a hobbyist, so I don't have access to parts.
      Just buying PCBs in order to test them is not feasible...
      Thanks,
      - Barak
      • barakm
        • Jan 2023
        • 24
        Just wanted to update that problem is resolved now, so I'm posting the solution for future use by others...
        Apparently, there were 2 problems:
        1. The sensor's shutter was getting stuck - this was fixed with a scotch tape over the "foamy" part on the solenoid housing.
        2. Print Unable 32 returned quite immediately. It ended up as a full/faulty waste toner container.
        To be honest - I'm a bit disappointed, since there are special error codes (and sensors) designated for the waste toner container.
        But anyway - it's working now.
        Thanks for the help!
        - Barak
          - Barak
          Congrats!.
          and thanks for the followup post as to the resolution of your issue.
