Help with Clogged Print Head
  • Cos
    • Jun 2023
    • 3
    I'm looking for some help with a clogged print head on a Brother MFW-J5730DW.
    I was not getting good prints so I did a Check Print quality and found that some of the cyan was not printing correctly and no matter what cleaning I tried, nothing improved it.
    I finally decided to clean with head cleaning fluid, after which I ended up with this:
    View: original size
    so I then decided to do a few strong print head cleaning cycles and ended up with this:
    View: original size
    which is where I started from when I started getting print problems.
    When I flush through with the head cleaner, I get a tissue full, and I mean wringing wet full, of blue inky solvent so there doesn't appear to be much of a blockage but the printer is insisting the head is clogged.
    No matter what I do I cannot get this back to how it should be.
    Does anyone have any ideas?
  • CroceL
    Sharp / Brother Tech
    • Jun 2020
    • 64
    Re: Help with Clogged Print Head
    Try Maintenance Mode SIM 76-4
    If this doesnt fix it you'll most likely need a new printhead.
    • Cos
      • Jun 2023
      • 3
      Thanks for this. No change after performing 76-4 under maintenance mode so looks like a new printhead may be needed
