Long format printer advice
  • davidwright1975
    • Nov 2023
    • 2
    Just incase I can't get any joy with my brother 8250cdn post I'm Looking for a colour laser printer that can be made to print Upto 2400mm long, normal a4 width 210mm is fine but need a printer that can be modified to print this length, longest I can find is Oki printers that will handle 1321mm long any suggestions welcome even if it's got to be modified as long as it will do the job
    Regards
    David
  • copyman
    Owner / Technician
    • Sep 2005
    • 4782
    Re: Long format printer advice
    Regards
    David
    I was going to suggest banner feature with Konica Minolta copiers but see you need 2400mm long. Kon/Min can only feed 457mm to 1200mm through the manual feed tray on side. You have to use folded "banner" paper.
