Brother hl-l3290cdw paper jam tray 1
  • bzuchero
    • Feb 2024
    • 2
    I have a Brother HL-L3290CDW. It says "Jam Tray 1" "Remove the jammed paper from Tray 1". There is no paper jammed. I called Brother, which was not much help, and they said it was a "Hardware problem." I have removed everything which is removable and there is no paper or paper fragments anywhere in the printer. Anyone had this problem and have a remedy?
  • tsbservice
    Field tech
    • 7998
    Re: Brother hl-l3290cdw paper jam tray 1
    Yes. Call a tech - problem solved.
    • bzuchero
      • Feb 2024
      • 2
      What Tech should I call? I called a Tech at Brother with no resolution.
      • dalewb74
        • Feb 2018
        • 1137
        sounds like you called brother support directly. and you probably got someone new. i would call a local shop to get a tech to come out to have a look at the issue.
