Brother 9440 unable to print 32
  • DaveTech
    • Jul 2008
    • 9
    Hi all,
    Just wondering if any one can point me in direction how to repair this fault code. One of my fellow techs was working on this machine and the following fault code came up Unable To Print 32.
    We normaly work on KonicaMinolta boxes bot these were bought in by a customer and we were asked to service them,it is the first problem that we have come across.
    We do not have a service manual and cant seem to find one.
    If anyone could help Id be very thankfull.
    Dave
  • DavidEtling
    • Feb 2005
    • 31
    Brother 9449 unable to print
    Here's what the Service Manual Says:
    Error code 32
    Print Unable 32
    Turn the power off and then back on again.
    Density sensor shutter performance malfunction
    User Check
    - Check if there is a scratch, dirt or the like on the belt unit. If there is, replace the belt unit with
    a new one.
    Step Cause Remedy
    1 Harness connection failure of
    density sensor holder ASSY
    Check the harness connection between the
    density sensor holder ASSY and registration relay
    PCB, and the one between the registration relay
    PCB and engine PCB. Then, reconnect them.
    2 Harness connection failure of
    density sensor solenoid
    ASSY
    Check the harness connection between the engine
    PCB and registration relay PCB and reconnect
    them.
    3 Density sensor holder ASSY
    failure
    Replace the density sensor holder ASSY.
    4 Transfer HVPS PCB unit
    failure
    Replace the transfer HVPS PCB unit.
    5 Engine PCB failure Replace the engine PCB ASSY.
    • DaveTech
      • Jul 2008
      • 9
      Thanks for that info very much needed, I am going to customers later on today Id say it is just the transfer belt.
      Thanks Again
      Dave
