Brother 4100 fax service mode
  • kradomski
    • May 2010
    • 5
    I need to be able to get into the service mode help please
  • kradomski
    • May 2010
    • 5
    I need to go in and change modem settings for line noise
      • 23003
      Menu, Mode, 0
      will get you into service mode.
      But I have to say that it's a bad idea to compensate for bad phone lines with settings. Bad phone lines only get worse, and never "heal". In this situation I advise customers to get their phone provider involved. Once the phone line is clean, then I'll change settings. =^..^=
      • kradomski
        • May 2010
        • 5
        Menu, Mode, 0
        Thank you, if i had access to the manual i would not have needed to ask, again thanks
          • 23003
          I think you missed the point. It's better to fix the real problem, aka the crappy phone line.
          You can get the manual at www.justmanuals.com , but it won't do anything for the phone line.
