Brother MFC-4750e Jams - need part ID
  • jsw2k
    • Oct 2008
    • 95
    OK...so it's jamming right at the registration roller. There seems to be a broken coupler; that is, I can turn the gear, but the roller doesn't turn.
    So I need the roller...or the coupler...or the drive assembly.
    Can anyone ID that part for me? I appreciate it. Thanks!
    • 23007
    The registration roller is figure 4-2, and the gear drive is figure 4-9.
    You can't really tell from a line drawing, but I'm thinking you'll find that 4-9 is plastic (and broken). You might also take a look at figure 4-13.
    registration roller: UL9060001
    drive gear/shaft: LJ5591001
    planetary gear assembly: LJ8985001
    see below:
    • jsw2k
      • Oct 2008
      • 95
      Thanks, 'Cat...you da man!. What I'm after is #10 in the pic above, UL907001, "Gear 21". It must be made of plastic. cause it don't make the roller move. Thanks a bunch!
        • 23007
        That's what I meant to say. On re-reading I identified the flub.
        Your welcome. =^..^=
