Brother mfc 8660
  • cucuklotz
    • Mar 2007
    • 611
    Brother mfc 8660
    When copying from original,or doing a test print directly from printer the machine prints a good quality copy or print. But when printing from computer program the prints are very lite. Can program on computer be adjusted for quality?
    ANDY
  • nmfaxman
    • 1702
    How does just a test print look? If it has good density, check the font color in that program.
    • cucuklotz
      • Mar 2007
      • 611
      Brother 8660 /quality
      HI,
      THe test print is a good dense copy.Ill tell customer to check fonts in program they are using(although I thought she checked that,but Im not sure).
      THANKS , ANDY
        • 23006
        What application?
        What application? Enterprise applications like Autocad, because there is a low fill rate can have light copies issues. On Copystar machines there is an FRPO setting to periodically increase agitation times in the developing unit to solve this problem. I can't say if Brother has addressed this or not.
        It may be specific to one or two applications and the density can be adjusted in the driver for individual documents, or a separate driver set up for that application, that is defaulted to a higher density.
