Brother HL-5440D Reset Fuser Counter
  • livewire
    • Sep 2011
    • 607
    Hi guys,
    I have a question for you.
    How to reset the fuser counter?
    In the service manual I could not find procedure.
    Fuser was changed during the warranty, but not reset.
    He has done 60K prints.
    Thank you.
  • theengel
    • Nov 2011
    • 1784
    Re: Brother HL-5440D Reset Fuser Counter
    Is it giving you an error?
    • livewire
      • Sep 2011
      • 607
      No, there is no error.
      The printer is working.
      Only recorded errors in the error history. Also there are status monitor message to replace the fuser and laser.
      I think, I need PJL file.
      Regards.
      • Elmtech
        • Nov 2013
        • 155
        Brother uses a software utility to reset the counters for machines without an led display. The utility is called brmainte. Google it for download sites.
        • livewire
          • Sep 2011
          • 607
          Thanks for the reply,
          I have software.
          Looking for specific PJL file to send it to the printer.
          Thank you.
          • Elmtech
            • Nov 2013
            • 155
            You dont need a pjl file with brmainte. Connect the machine to a pc open the program select input information from the menu select your model and there should be a list of functions. One will be reset fuser count.
            • livewire
              • Sep 2011
              • 607
              I will try this soon and post info here.
              Thank you.
              • damy
                • Aug 2017
                • 13
                does anyone have the program brmainte to reset HL-5450?
                • dalewb74
                  • Feb 2018
                  • 1117
                  you do not need a specific file nor a software program in order to reset the fuser.
                  • damy
                    • Aug 2017
                    • 13
                    so how to do it? I need to reset the laser, fuser and pz kit
                    • tsbservice
                      Field tech
                      • 7909
                      Partially correct. For LED models you actually need a specific file and software program.
                      LED model
                      (1) Open the front cover. Press and hold the[Go] button, and turn ON the powerswitch of the machine. Check that theBack Cover, Toner, Drum, Paper andError LEDs light, and release the [Go]button. Check that all LEDs go out, andthen press the [Go] button for at leasttwo seconds. The Paper LED lights, andthe machine enters maintenance mode.
                      (2) Connect the computer to the machine with the USB cable.(3) Double-click "FILEDG32.EXE" on the computer to start it, and select the "BrotherMaintenance USB Printer".(4) Drag and drop the periodic parts resetting PJL file onto the "Brother Maintenance USBPrinter" icon.(5) Turn OFF the power switch of the machine.
                      • damy
                        • Aug 2017
                        • 13
                        Hi, thanks for reply. I dont have FILEDG32.EXE
                        • dalewb74
                          • Feb 2018
                          • 1117
                          if you don't have the file. then it is time to contact brother to get the correct file needed. if you load an incorrect file you can brick a machine.
