HP 5500n
  • hsrmms
    • Dec 2014
    • 69
    HP 5500n
    Customer had HP Laser Jet 5500n and he couldn't print both side automatically as we know it is impossible with 5500n.
    Is it possible to download firmware for 5500nd to 5500n to able to print duplex automatically.
    Regards.
  • _SuabE_
    • Jan 2008
    • 108
    Re: HP 5500n
    Regards.
    You need this conversion kit from simplex to duplex see as sample ...
    Simplex to Duplex Formatter Upgrade Kit for HP Color LaserJet 4600 & 5500 Series Printers, C9661-67902-AEX
    sigpic
    Senior Technician Specialist
    A+; Network+
    Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
    Printer Handled: Canon, HP, Epson, Brother, Samsung
    Duplicators: Risograph, Duplo
    • theengel
      • Nov 2011
      • 1784
      Re: HP 5500n
      Regards.
      You might be able to. From the looks at the link above, the only thing different is the firmware. But I've never personally tried it. I might go try it on a 4600 right now just to see. If I do end up trying it, I'll report back.
      • theengel
        • Nov 2011
        • 1784
        Re: HP 5500n
        Sorry -- both the 4600's I have are already dn.
        • hsrmms
          • Dec 2014
          • 69
          Re: HP 5500n
          Originally posted by _SuabE_
          I have similar of this kit but do you have last version of firmware for HP 5500nd and I will try uploaded to HP 5500n to see if it works.
          Regards
          • subaro
            • Oct 2010
            • 1274
            Re: HP 5500n
            HP Support document - HP Support Center
            Most hp firmware are downloadable free of charge from hp website.
            Not advisable to use usb method. use ftp, its simple and i never had problems with this method. usb can be problamatic and can cause hangups . you can also use crossover cable .
            By the way. why go through the trouble to buy upgrade kit ect. the cost for that, plus the time, it would be cheaper to use for a used 5500dtn, i would think.
            • Printerdude
              • May 2015
              • 119
              Re: HP 5500n
              A firmware will not change a non duplex model to a duplex model. Just get a used 5500dn/dtn formatter from a reliable source or get the duplex upgrade kit.
              • theengel
                • Nov 2011
                • 1784
                Re: HP 5500n
                Apparently, the "upgrade kit" is just a new formatter.
                • subaro
                  • Oct 2010
                  • 1274
                  Re: HP 5500n
                  Regards
                  Clearly,[ _SuabE_ ] had replied with the solution for this guy request, the upgrade kit, which is essentially the formatter. He said he has this kit and still wants to upgrade with firmware to make it work. This thread should have ended when SUABE posted the solution. Whenever boards or options are replaced and added though, the firmware should be updated.
                  • Printerdude
                    • May 2015
                    • 119
                    Re: HP 5500n
                    Regards
                    In defense to your post, you are wrong this time. Did you read his post? He is trying to upload the firmware to make a "5500N to a 5500DN". He did not say he is trying to upload the firmware to a "5500DN formatter or upgrade kit". The original question was:
                    "Is it possible to download firmware for 5500nd to 5500n to able to print duplex automatically". Answer to this question is NO!
                    • theengel
                      • Nov 2011
                      • 1784
                      Re: HP 5500n
                      So you've tried this? Just curious.
                      • Printerdude
                        • May 2015
                        • 119
                        Re: HP 5500n
                        No, but why would HP let you download something for free to upgrade your printer for the better. One firmware for multiple models in the same series. It's in the board or the dimm. HP 5500 firmware download not found on HP site.
                        • subaro
                          • Oct 2010
                          • 1274
                          Re: HP 5500n
                          I quite understand that. I think you need to reread my post again. we are saying the same thing. my point is a previous poster showed him it is a hardware fix and not software. later on he said
                          If every question here is answered with a yes or no, then the forum would be quite messed up. you also have to have a bit of logic in your question and answer.
                          • theengel
                            • Nov 2011
                            • 1784
                            Re: HP 5500n
                            So all you have to do is order the firmware, right? You don't need a whole other formatter.
                            • subaro
                              • Oct 2010
                              • 1274
                              Re: HP 5500n
                              I beg to differ on the highlighted quote . the rest i agree with.
                              Drivers & Software - HP Support Center.
