HP laserjet enterprise flow M880z+
    • 23010
    Doesn't it just trip off your tongue? I wonder if they couldn't have thought of a longer name?
    I'm looking for a part number for light source #1, aka CIS assembly. The one in the scanner. I found a manual on Liberty, but they conveniently clipped out the parts list.
    My symptom is a gray line down all scans and copies, and I've successfully moved it around a little, but I don't have a small enough Torx bit to get into the scanner. It must be T6, T5? Something like that. It's probably just dirt, but it won't come out. Part number please? =^..^=
  • Hewlett Slacker
    • Apr 2015
    • 42
    Re: HP laserjet enterprise flow M880z+
    pm your email and ill send the complete manual
    • Printerdude
      • May 2015
      • 119
      Did you try making a copy from the glass itself to see if it does the same thing?
      Get that Torx bit! Checked the parts manual and this part is not listed. Knowing HP, you have to buy the scanner unit.
      • _SuabE_
        • Jan 2008
        • 108
        HP_LaserJet_ENTERPRISE_M855-M880.rar ==>> DepositFiles
        You will find it here
        Cheers
        sigpic
        Senior Technician Specialist
        A+; Network+
        Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
        Printer Handled: Canon, HP, Epson, Brother, Samsung
        Duplicators: Risograph, Duplo
          • 23010
          Originally posted by Printerdude
          Did you try making a copy from the glass itself?
          I bought a T4, T5, T6, T7, T8, T10 kit today. I'll try it out tomorrow.
          It figures that HP would sell the scanner as an assembly.
          Off the glass I get a similar band, perhaps 15mm wide, and slightly more faint, roughly same location. It does not appear on the 2nd side CIS. And in my efforts to blow it out the first time I moved it over about 10mm. The only real risk is changing some focus fine adjustment.
          My guess is that an insect crawled in there and died. =^..^=
          • Printerdude
            • May 2015
            • 119
            "My guess is that an insect crawled in there and died"
            HaHa! Good luck!
              • 23010
              Following up:
              It took the T6 and T10 Torx tips to partially disassemble. The extruded aluminum side is attached by a very tight ribbon cable. limiting how far you can move shift the pieces. I was able to get a Q-tip inside and clean some blueing off the mirrors. The lamp side disassembles a little further. No improvement though.
              The part number for the scanner assembly is not a valid part number (CF367-60106). I ended up getting a document feeder assembly. By proximity it's close, but won't do a thing for my scanning problem.
              Does anybody have a retired or slightly damaged M880 with an intact scanner they can sell? Or even just light source #1 with the ribbon cable? =^..^=
              • Hewlett Slacker
                • Apr 2015
                • 42
                Following up:
                Sorry man I had to send mine back for warrenty, all i have is the scanner control board.
                  • 23010
                  The scanner resolved it. The part number that finally arrived was A2W75-67908. The original scanner had a whopping 3900 scans at time of replacement.
                  Notice how the shaded area on the glass starts 6mm lower on the page than through the DF, and 7.7mm wider. I'm having a hard time explaining that. =^..^=
                  • Hewlett Slacker
                    • Apr 2015
                    • 42
                    ugh, was it under warrenty?
                      • 23010
                      I suspect yes, since my parts guy requested the core for return. =^..^=
                      • theengel
                        • Nov 2011
                        • 1784
                        There's gotta be some kind of registration setting for the DF??
                          • 23010
                          Nope. It's the same DF connected to the same scanner board. It's just sitting on a different piece of glass. The only reset is the flatbed count. It was actually far easier than cleaning the stupid optics (that didn't work, by the way). Just expensive. =^..^=
                          • Brian G
                            • Mar 2015
                            • 21
                            I know this is years past when this was created but I just ran into this issue and you can just buy the scanner optic piece. The part number is C8569-60001 and it costs a lot less than the entire scanner assembly.
                              • 23010
                              It's a bit late ... but thanks. I hope all those 880's are gone now. =^..^=
