HP Laser Jet M880 fuser error
  • Lagonda
    • Aug 2008
    • 1649
    Gentlemen,
    May I first apologize for not being able to speak a word of HP?
    I normally stay well over on the Ricoh side of the fence, but due to a salesman promising the world without checking that the service department could actually deliver I have a very dead HP in my workshop.
    It appears to have a 240 volt short circuit problem as in the field it was tripping the office circuit breaker and blew the 15 amp fuse on the PSU. I've obtained a second hand fuser and now the copier just sits there and says 50.4F.00 but at least its not blowing fuses.
    Can someone enlighten me what a 50.4F.00 code means and point me in the right direction to solve it?
    • 23010
    Re: HP Laser Jet M880 fuser error
    The fuser is powered by the power supply, so if you have any confidence in your borrowed fuser, I would replace the power supply. The blown fuse may just be the most obvious flaw. I'd offer you a number, but you won't need a 120vac power supply. =^..^=
    • Lagonda
      • Aug 2008
      • 1649
      Thanks BC, are they like Ricohs and you have to reset a SP mode to clear a fuser code?
      • NeoMatrix
        Senior Tech.
        • 3513
        Some of the HP's you just have to turn the machine off an then back on to reset the fuser code.
        • Lagonda
          • Aug 2008
          • 1649
          Who ever designed the panels for this clunker should have his genitals removed with an angle grinder!!! Why do you have to remove the bridge unit to do something as simple as take the back panel off?
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            I believe every design engineer for every copier company has had his wife run off with a field tech, and things like this are part of their sick twisted revenge.
            • NeoMatrix
              Senior Tech.
              • 3513
              .... haha I feel the usual thread digression coming on......
              • theengel
                • Nov 2011
                • 1784
                I love that. I'm using that from now on.
                • Lagonda
                  • Aug 2008
                  • 1649
                  That was my fault, I should know better by now. All I'm going to get now is whinges about copier designs and all I really wanted was a technical explanation of what caused a 50.4F.00 code.
                    • 23010
                    No System Error Reset (like Konica Minolta). No U906 Partial Reset (like Kyocera). No Function > Error > Reset (like Canon). No sim U14/U15/U16 (like Sharp).
                    Just power Off/On, and if you resolved the problem it will go away. =^..^=
                    • Iowatech
                      Not a service manager
                      • 3930
                      I don't know how much this will help as it is from the M600 manual, but that says a 50.4X.YZ error means the machine has detected an over temp issue in the fuser (for what it is worth, the manual helpfully further explains only that "X"= the fuser mode, "Y"=previous printer sleep state, and "Z"=next printer sleep state, but not which each of those means exactly).
                      If you've ever worked on old Canon fax machines, that experience can be helpful with HP equipment. I mean, I apologize if you've already done this, but you should turn the machine off and unplug it for a while (I don't know, get a cup of coffee or something, that usually works for me, although it could need to be unplugged for around ten minutes so take your time if possible). And maybe check the outlet the machine is plugged into to make sure it's up to spec.
                      Anyway, back to the manual, such as it is. It says if the fuser is OK then to check the connector for the fuser for damage or not being plugged in correctly, and then replace the low voltage power supply.
                      Also for what it is worth, here's something I found on HP's support website that might be more helpful than me:
                      • Lagonda
                        • Aug 2008
                        • 1649
                        Thanks for your input Gentlemen, problem now solved.
                        It appears that something went short circuit in the fuser and took out the 240v board that controls the fuser.
                        Fortunately I had access to another M880 that I could use as a test box. Now I just have to wait for a new fuser to come off back order.
                        p.s. please don't tell anyone I worked on an HP.
                          • 23010
                          ... p.s. please don't tell anyone I worked on an HP.
                          Your secret is safe with me. =^..^=
                          • MStalkfleet
                            • Apr 2011
                            • 41
                            HP what HP??? Don't know what you are talking about. Just make sure your Sales rep doesn't get wind of you fixing the issue.
                            • tech28
                              • Jun 2013
                              • 434
                              Service friendly,
