HP Laserjet 600 m601 noise
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Machine makes slight squealing noise running letter plain from tray 2 and MP tray. Customer runs envelopes thru MP tray and noise is much worse. Have changed fuser, toner cartridge, cleaned and lubedd registration assy, and lubed drive gears to no avail. Posting video to show sound.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
  • Hewlett Slacker
    • Apr 2015
    • 42
    Re: HP Laserjet 600 m601 noise
    check that toner cartridge, sounds like the drum to me.
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      weve replaced that
      • Printerdude
        • May 2015
        • 119
        Sounds like a toner cartridge issue, when you print from tray 1 the noise is a higher pitch than tray 2. Since the paper travels through tray 1 at a slower rate the noise is louder and longer than tray 2. If you are using remanufactured toner cartridges this is definitely the cause of the noise. You can run a component test to eliminate components that are failing.
        • 1stcavvet
          • Apr 2015
          • 231
          replace the output assembly I had to do 2 of them, put your finger on the white plastic piece in the middle of the output,(where the paper come out) it either gets noiser or quieter GOOD LUCK
          • Printerdude
            • May 2015
            • 119
            Very good observation.
            • Blizzoo
              • Aug 2013
              • 608
              That noise is an "electric noise". Had to do with that when a defective cartridge or bad contacts between cartridge and printer were bad,maybe hv board (not on this hp printer)... I watched your video and the noise is present just when the paper/envelope is printed. Sounds stupid , I know.
