I worked on this CP 2025 at the customer location. This printer is in "mint" condition. The customer will try to print to this machine and it will jam out of tray 2 and 3. (Just as the paper is feeding out of the paper tray.) When I brought it to my shop I ran internal prints ie... config, demo, pcl font list. It never jammed once. Took it back to customer and he prints to it and it jams just as it did before. Could the drivers be causing this.
HP CP 2025, Can the drivers cause jams ?
Re: HP CP 2025, Can the drivers cause jams ?
A couple things I'm thinking of here.
Are you using different paper when you printed internally at your shop. (I.E. are they running card stock vs. you running plain paper)?
and
Can you run internal prints AT YOUR CUSTOMERS OFFICE without jams.
and
Are they even using the correct driver?
and
maybe somehow the preferences in the printers properties are asking for a different size of paper, than what is in the drawers?
but
I have never heard of the driver causing paper jams, but if all the above are in good order, it is worth trying a new driver.
There's a first time for everything. I'd like to know the outcome. -
and
and
and
but
There's a first time for everything. I'd like to know the outcome.Comment
What happens when you crossover to your laptop, download a driver and print directly? =^..^=If you'd like a serious answer to your request:
Well if you took it back to the shop, how come you did not test it from your computes there[ don't get that as you are testing printing problem]. I would download the HP universal driver and install it on your laptop and test the machine. [ Every hp tech should have the universal driver as you don't have to keep installing drivers for each machine you service and may want to test.]
What are the jam codes ?, you did not list any. from the web admin you can view it there.
Event log-- The Event log is a table that contains codes corresponding to error messages that have appeared onthe product control-panel display, a brief description of each error, and the number of pages that printedwhen each error occurred. For more information about error messages, see Event log on page 202.
does it jam from tray 1. set the machine to print from tray 1 first.
HP Universal Print Driver (UPD)
The HP Universal Print Driver (UPD) for Windows is a single driver that gives you instant access tovirtually any HP LaserJet product, from any location, without downloading separate drivers. It is built onproven HP print driver technology and has been tested thoroughly and used with many softwareprograms. It is a powerful solution that performs consistently over time.The HP UPD communicates directly with each HP product, gathers configuration information, and thencustomizes the user interface to show the product’s unique, available features. It automatically enablesfeatures that are available for the product, such as two-sided printing and stapling, so you do not needto enable them manually.For more information, go to www.hp.com/go/upd.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
Ended up taking the printer back to the customer and told them to get with an IT tech.Comment
