Color LaserJet 4700 colors misaligned
  • Lance15
    • Jun 2015
    • 1089
    Got a call for misaligned colors. Knowing they use remaned carts, I assumed bad carts. Well, I can be satisfied it isn't the carts. I took the problem carts (magenta, yellow & cyan) to another 4700 and everything is aligned properly. The problem stayed with the printer. It almost looks like the laser shutters are just not open enough. If anyone has seen this or has any ideas, I'd love to hear about it. The only option I have left is to open it all up and check the laser/scanners for those colors.
    Any help is very appreciated!
    Thank You
    Lance Gentle
  • theengel
    • Nov 2011
    • 1784
    Re: Color LaserJet 4700 colors misaligned
    You're not just looking at the cartridges and how they interact with the machine. You're looking at a love triangle between the machine, the transfer belt, and the cartridges. An OEM transfer belt with OEM cartridges should solve your problem. Sometimes a reman belt with reman cartridges will work... sometimes not. The most often failed is when one is OEM and the other is reman. But also, an old belt that needs to be replaced will cause misaligned colors. So start with the belt--an OEM one. Then replace the cartridges with OEM.
    • Users Tech
      • Nov 2013
      • 85
      have you tried cold reset and full calibration? or pressing the engine test switch?
      • theengel
        • Nov 2011
        • 1784
        That's right... I forgot about that. Sometimes a cold reset, or a NVRAM dump will fix alignment problems.
        • Lance15
          • Jun 2015
          • 1089
          Thanks angel, but in reality, unless it comes to you GOTTA use genuine cartridges (which I 110% wish people would), I gotta troubleshoot with what they use (unless proved otherwise). Considering the remaned carts tested fine in another printer. I'll go back and try a belt swap & cold reset and see what happens.
          Thanks to all. I'll keep the thread updated.
          Lance
          • Dickie
            • Nov 2011
            • 190
            Had same problem earlier this year and cartridges were not to blame.
            Laser re alignment procedure is as follows
            Let machine warm up and indicate ready
            Open upper fuser cover
            Press and hold engine test button on rear for 3 seconds
            Close upper fuser cover
            Immediately turn power switch off & back on again
            This puts the lasers back to factory setting and then let the machine calibrate itself and all is normally o.k.
            For what it's worth, my take on this is that by using non original cartridges all the lasers self adjust to compensate for them.
            Eventually when they have all moved away from factory settings and a new cartridge wants to move further to rectify alignment, it becomes impossible to move any further.
            The factory reset then gives it the opportunity to start the process again from scratch thus making the alignment possible again
            Good luck
            • Lance15
              • Jun 2015
              • 1089
              Tried the laser/scanner factory reset procedure. No change, so I took the fuser & ETB from another 4700 in the building. Swapped the fuser. No change. Swapped the ETB. BINGO!
              Thanks for the suggestions all!
              • lplandin
                • Jan 2016
                • 28
                Thank You
                Lance Gentle
                [ATTACH=CONFIG]31524[/ATTACH]
                Run full calibration about 3 to 4 times to see if they realign, if not replace the toner cartridges.
