HP P3015 -- Dual NIC setup for printing from two subnets?
  • Kyser
    • Mar 2014
    • 9
    Hey guys, I have a P3015 at a school with two different subnets (one internal and external). I know the 3015 has an internal NIC and an expansion slot where I can add a Jet Direct card. Does anyone know if it will support both NICs at once so I can run one on subnet 10.1.1.x and one on 10.1.2.x? My gut tells me it'll disable the internal if another is added but unfortunately I don't have anything laying around I can test..
    • 22997
    Re: HP P3015 -- Dual NIC setup for printing from two subnets?
    I've done something similar. It will work just fine. Also consider using a USB to TCP/IP print server. Something like this:
    Port USB 2 0 TCP IP LPR DHCP Network Terminal Print Server for 10Base T Networks | eBay
    • Kyser
      • Mar 2014
      • 9
      Thanks for the input! I didn't even think of the USB print server!
