Re: HP 1320 need second opinion.
I found the same printer headed for the junk pile, Just killed yesterday, customer refused est. When the tech who worked on it comes back tomorrow I will find out what is wrong with it. It may have needed a paper tray or something simple. If that is the case,I will take the easy way out. Basically plan to swap the printers and swap the data plate for serial number. I will try the cartridge first. If it was a bigger issue that killed it, I have a power supply to swap without the customer to having to eat it. Was a little uneasy about buying the power supply without someone else having had a similar issue. Will update tomorrow.
