Rebuilding HP fusers
  • theengel
    • Nov 2011
    • 1784
    Does anyone here rebuild their own HP fusers? I'm thinking of trying it for a while. Where do you get fuser parts?
  • walterman
    • 196
    Re: Rebuilding HP fusers
    Have you tried, TSA World Inc. or Metro fuser?
      • 23009
      Between TSA World and Precision Roller, you can get what you need for the most part. It really helps to write down the reason that the fuser is getting replaced, so that when you finally get around to rebuilding it, you can make sure to check the appropriate parts. =^..^=
      • theengel
        • Nov 2011
        • 1784
        Now that I'm looking at the parts costs, it doesn't make much sense for me unless I'm buying in bulk. All the parts together add up to just a little less than a refurbed fuser.
        • Bradmatt
          • Apr 2015
          • 4
          Some parts are available on eby but quality is low
