4250/4350 dc controller/formatter relationship
  • GAtech
    • Jan 2015
    • 20
    If you have a used controller from a 4350n and a used formatter from a 4250n. What will the machine wind up as?
    I say 4350n and we have used 4350n controllers to upgrade 4250n printers with success.
    But alot of people are selling used controllers and formatters as universal. I think the formatter is universal. Not the dc controller.
    Thoughts?
    Sent from my SM-G900P using Tapatalk
  • subaro
    • Oct 2010
    • 1274
    Re: 4250/4350 dc controller/formatter relationship
    Thoughts?
    The reverse is true. the dc controller is common and the formatter is different. Easily verifiable by looking at the parts manual. hopes this help
    • GAtech
      • Jan 2015
      • 20
      In the service manual the dc controller and formatter are both universal across the 4250 and 4350. There are different formatters for network and base.
      new boards are blank/neutral. So when installing 2 used boards with different models which one wins?
      • GAtech
        • Jan 2015
        • 20
        So i found this article and it confirms my thoughts
        HP LaserJet 4240n, 4250 & 4350, DC Controller - Model change & speed upgrade, RM1-1108-180, The Printer Works
        does anyone know how to make a dc controller blank?
        • subaro
          • Oct 2010
          • 1274
          Acutally from the normal tech using the service and parts manual to order parts, the part numbers for the the two models are diffrent for the formatter and the same for the dc controller.
          Formatter, LJ 4250/4350 (base models) Q3653A Q3653-67901/Q3653-69001
          Formatter, LJ 4250/4350 (network models) Q3652A Q3652-67901/Q3652-69001
          Dc controller (LJ 4250/4350) RM1-1108-000CN.
          What printer works has described is what they have found to be a manipulation of the boards that hp has allowed and which makes a mess of things for the simple tech who just wants to follow procedures for the repair of a machine. As you can see from the above, if i order a 4250 formatter from hp ,they would not send me a blank board. If you buy used then as the article described, you can be screwed as NVRAM will be at play. [ doing nvram may make the board blank , try at your risk ]
          Initializing the NVRAM resets the serial number, the event log, the page counts,
          the EIO card, and the embedded print server. Initializing the NVRAM also resets service-menu
          values to factory defaults.
          • GAtech
            • Jan 2015
            • 20
            (notshown)Formatter assembly (LJ 4250/4350 printer, base model)Q3653-679011(notshown)Formatter assembly (LJ 4250/4350 printer, network models)Q3652-679011
            This is from page 483 of the manual. One part number for the network version. I think you got your info from page 453 and those part #s are for outright or exchange.
            And my situation revolves around used boards, so printer works article is completely relevant.
            • subaro
              • Oct 2010
              • 1274
              [QUOTE=GAtech;510066](notshown)Formatter assembly (LJ 4250/4350 printer, base model)Q3653-679011(notshown)Formatter assembly (LJ 4250/4350 printer, network models)Q3652-679011
              Yes, you are absolutely correct. usuall i would look at the diagram and then get the part number, but i started from the top and saw the one i posted. So in that case i see question that makes sense now. thanks for the correction.
              someone may have invested the time to make a service tool to access the registry of the controller that stores that information as they may see it valuable to make a profit in clearing the boards and selling as blank.
              • subaro
                • Oct 2010
                • 1274
                So is the speed difference quite noticeable. 4250 is 45ppm and 4350 is 55 ppm. long time since i have seen a 4350. for me i don't think is that a big deal. i have a 4250 and when it gets going it is fast enough.
                  • 23010
                  It sounds to me like you found your answer:
                  "For the purposes of recovering inadvertently lost model settings, boards can also be sent to our repair depot in Hayward, CA, and for a fee we will reprogram the settings to become the model needed."
                  • GAtech
                    • Jan 2015
                    • 20
                    I was looking to see if anyone knew how to do it without sen ding the boards out.
                      • 23010
                      From what I read, you'll have a very nice doorstop. =^..^=
                      • subaro
                        • Oct 2010
                        • 1274
                        when the manufacturer do things like this, it allows for chaos when machine change hands ect. as who does who knows what and thus the creation of a whole bunch of wasteful time and calls and proddings ah. over to you blackcat. but as human, he has a valid point to seek to take advantage of that open door.
                        • subaro
                          • Oct 2010
                          • 1274
                          This reminds me of lexmark. They have a situation where you have to install a new board from the factory if you want to use it permanently. You cannot use used boards or any functional items that contain nvram from one machine to another. nvram mismatch error would be posted on boot screen.
                          I see that as a lot of e-waste as good boards just get thrown in the garbage when they could have been used in another machine. I dislike lexmark very much on that issue. They are decent machines overall, but why this prevention of using used boards ?. kyocera on the other hand is tolerant, just swap the eeproms.
                          As i see it, we can only inhabit this earthly planet at the moment and we have to put aside petty and stupid business practices if we want the future generations to enjoy what we have been privileged to thus far.
                          • Printerdude
                            • May 2015
                            • 119
                            Sorry, you won't find/get it at any price. Just send it in or buy a new board from HP.
