hp LJ5 Si MX
  • tcypy1961
    • 773
    [Misc] hp LJ5 Si MX
    customer has purchased 4 printer cartridges and all 4 are not working; it appears the drum cleaning blade is not engaging with the drum; if this is the case is there anything other than removing strip to release toner that needs to be performed??? The cartridges do have the hp label on them yet I'm thinking these are refilled/refurbed cartridges. Any help would be appreciated!!!
  • Santander
    • May 2009
    • 768
    Re: hp LJ5 Si MX
    The only thing the user has to do on the cartridge is pull the tape off. While we have seen a user pull the tape where it breaks this usually results in light or no image on the page as toner is not getting to the drum. You say that it appears that the drum blade is not making contact, what do the prints look like? Even with reman cartridges four in a row is highly unlikely. I would suspect the transfer roller is either very dirty or defective, that would be where I would start.
      • 22930
      Re: hp LJ5 Si MX
      The drum cleaning blade should be in contact with the drum at all times. There is no mechanism to back off the blade. So if the drum isn't cleaning it's a problem with the cartridge. If it were me I would bring out an OEM cartridge (if they still can be got). If it works, you're done. =^..^=
      • subaro
        • Oct 2010
        • 1273
        Re: hp LJ5 Si MX
        Really, you have not describe a problem, but gave an opinion of what you think is happening with the cartridge. It would be that you give a description of what is actually happens when the print image. I think most will have an imagination of what the print looks like with the cleaning blade not touching the drum, but as the other mentioned, that is unlikely with all four cartridges. what does the output image looks like ?. imagine there is no heaven.
          • 22930
          Re: hp LJ5 Si MX
          I'll agree that you would get better information from us if you gave us a chance at the diagnostics. Include a quality sample.
          • tcypy1961
            • 773
            Re: hp LJ5 Si MX
            [ATTACH=CONFIG]32758[/ATTACH]
            The print cannot be seen due to haze all over paper which is also seen all over drum....
            • tcypy1961
              • 773
              Re: hp LJ5 Si MX
              The image of the print(Menu Map) can't be seen due to haze all over paper which is seen on the drum; manual rotation of the drum will not clean drum off; if I sent sample I'm not sure it would do anymore than what has been described(drum not being cleaned)
              Thanks!!!
              • subaro
                • Oct 2010
                • 1273
                Re: hp LJ5 Si MX
                Thanks!!!
                Usually, if i get something like this, i would disassemble the cartridge and see to see what's happening in there. But four cartridges doing the same, something not right there. take the old cartride that was working and comapre it with the new ones you got and see that it matches the gears ect. Thinking if those cartridges is for another model like the 9050 or so. just a thought.
                rotate the drum in the opposite direction for a quarter turn or so and see how the drum looks. if the same image, then the cleaning blade may be missing altogether.
                • Wild Bill
                  • Jul 2005
                  • 774
                  Re: hp LJ5 Si MX
                  It is an old printer. They had those toners collecting dust and shipped them to you and said Sucker!~ After so many years they might not work so good.
                  Izzy
                  • Santander
                    • May 2009
                    • 768
                    Re: hp LJ5 Si MX
                    Is the laser slit glass clean? If memory serves me correctly, the 5si is a write white machine [somebody correct me if I am wrong] meaning that the laser beam removes the charge on the drum where there should be no toner. So if the slit glass is dirty it will block the laser beam from erasing the charge on the drum resulting in dark background on the page.
                    • sandmanmac
                      • 3964
                      Re: hp LJ5 Si MX
                      First off..... Why is this so-called "customer" not buying the product from you? ...Or did they?
                      The product is obviously defective, since you say there is CRAP all over the surface of the drum.
                      If it were a product I supplied, I would simply replace it for free, and then go and tear my supplier a new one!
                      If they're getting them elsewhere, show them the crap on the surface, tell them to take it up with their supplier, and leave them a bill for your time, explaining that it wouldn't have cost anything if they'd come from you.
