hp designjet t2300 vertical lines are bad
  • javier4065
    • Feb 2007
    • 251
    I do printheads alignment and display says ok, when I print a configuration page vertical lines are bad. horizontal lines are good. I did several times printheads alignmet, and I have the same problem,Maybe I must configure it or something is wrong. Thanks in advance.Maybe I must use hp media to calibrate printheads.
  • theengel
    • Nov 2011
    • 1784
    Re: hp designjet t2300 vertical lines are bad
    I'm not sure, without a pic, which lines you mean. I'll give you advice on both.
    Do a paper advance calibration. Then clean your encoder strip with a soft, wet rag (water only).
    Actually--clean the encoder first.
    • Kiran Otter
      • Dec 2013
      • 1116
      My vote would be the belt needs replacing.
      Kiran
      • javier4065
        • Feb 2007
        • 251
        Kiran
        thanks, i will check the beltand encoder.
        • pbrooks259
          • Jun 2017
          • 162
          I know, it's been a few years, but what resolved the vertical line misalignment on the T2300?
          Thanks.
